I have a 1996 7.3 with 243,000 miles on it and has Ben not running for over a year now. the truck starred to have a knock and stuttered when you gave it throttle. Here’s the link to what it sounds like.
Discussion Starter · #2 ·
At the filming of this video I had not yet replaced anything since then I have put an idm icp and CPS in it and has only got worse
I would start with the basics. The attached has a lot of the basic things to check. You may need to use a scanner app with an interface adapter (would be in place of the NGS tester mentioned ... something like the Forscan App) for some things. Look at fuel pressure and maybe the IPR (solenoid nut and wiring harness). Cheers!
Thanks for the advice the truck isn’t in running condition right now. I’m waiting on a few parts then I’ll have an update.
