Is this normal sounds for a 7.3 powerstroke is it knocking. It has been just dying going down the drive it over and hour never died once. Got in to take a ride it died started right back up.
Drove down the road wait start light came on then when you press the gas nothing happened then it took off but didn't die.
Turn into the driveway and it just died again then started right back up. Any ideas I changed the oil filter, oil,fuel filter, icp sensor, gpr ,cps sensor, new battery terminal cables. It sat the other day and die while idling it does have a fuel leak would that cause it to die . Just need some help.
