21 - 27 of 27 Posts
1999 f350 7.3 power stroke crew cab 4wd dulley
Discussion Starter · #21 ·
all the ones that I see online or remanufactured you have to send them your DM and then they rebuild it and send it back to you looks like it takes a couple of weeksIf you know of somewhere where I could just buy one let me know please and I’ll keep looking again thank y’all very much for your help
Discussion Starter · #22 ·
Hey one more question is there anyway that I can Taste that IDM To check to make sure it’s bad
Discussion Starter · #24 ·
Test not taste That’s what happens when you talk dicks it never comes out right lol
No I don’t know where that came from it was supposed to say talk text not that other word I apologize for that like I said I don’t know where that word came from let’s see if it works this time
I may be chasing a squirrel here, but did you happen to check the little metal nut on the IPR that holds the coil on the stem. That happened to me at a red light once. Truck was erratic. Changed the cam sensor to find the little nut laying in the valley and the IPR coil sliding back and forth.
Discussion Starter · #26 ·
Finally got my truck fixed it was the IDM and The Hi oil pressure sensor it had oil in the electrical connections so I figured it was bad but IDM did the trick and I guarantee you I could’ve done it without y’all I appreciate all the help from everybody and the schematics everything all the information everything I do appreciate it I can’t tell y’all how much I appreciate it
Discussion Starter · #27 ·
Truck is running better than it has since I can remember thank y’all so much
21 - 27 of 27 Posts
