Hi I’m new on here . Have a big problem with my early 99 7.3 powerstroke with 415k miles . So here is the story . I bought the truck with a long crank condition . Had to crank it for about 30 seconds and then soon as it warmed up it stalled and wouldn't restart . I solved those issues . The problem was bad glow plugs and a bad hpop. No the truck fires on second turn and wont die out no more. Problem Im having now is that it idles perfect but soon as i drive it its a complete dog . Here is a list of things I did so far :
new ipr (oe not the cheap crap )
new icp (not oe)
new exhaust back pressure sensor and tube
2 new fuel injectors ( #4 and #8 both failed and after replacing passed a balance test )
new hpop ( the new pump is leaking on the round back piece . Seen that today. The readings on my scanner at idle are 480-530psi and 2400-2600 on wot)
all new fuel injector o rings (all oe brand )
replaced both under valve cover harnesses and valve cover gaskets .
motorcraft glow plugs .
it seemed like a boost issue so i replaced the turbo pedestal and did a ebpv delete .
turbo o rings are all new too .
turbo was fully checked while out . No play in the shaft and everything else checks out too .
I thought maybe a compression issue so I checked that and the numbers were 370 380 400 400 - 400 380 390 400 . The test was done on a cold engine so should be even a little better .
AI fixed all the codes with the work I did to it except the code for the ebpv but that will stay on because of the delete . When I have it in neutral it will rev to 3000 but it takes a second to get there . Quick at 2000 and then dogging a little to 3000. I can hear the turbo spooling . In gear it wont pick up speed quick and it wont shift right away and then hits hard in second . Also every once in awhile when I rev it in neutral the overdrive flashes and i get code p0500 (speed sensor in differential) and p0720 (transmission output speed sensor) i already replaced the one in the differential . Soon as I restart it the 2 codes are gone . I think more its an engine issue that causes the rough shifting and codes . I pretty much replaces everything except 6 injectors and also didn't replace the map sensor but it reads right on my scanner . I need help with this truck . Oh and also I replaced the fuel pump blown out all the lines , replaced the return valve , pulled gas tank and checked the screens in the pickup and return and also installed a new screener and fuel filter . Fresh diesel and I did the arch oil cleaning which helped a little .it made the truck more quiet . The 6 old injectors are all shimmed not sure if that could cause a issue. I do not have any imbalance codes at all . And i did replace all high pressure oil lines and added a crossover line so number 8 gets more oil. That got rid of the injector tick . I replaced everything got rid of all the codes and i don't have a truck with full power .could use some help . Also have to say the truck does not smoke at all.
that's on idle
that's flooring it . The injector control pressure goes up to 2400-2600 but it takes a second to get there. Maybe the pump has a problem due to the leak
new icp (not oe)
that's on idle
