so today I changed the up pipes out with them bellowed ones. still don't have boost. I took it on the street today and hit it a little bit. it's a dog pretty bad. also smoke for a second but stopped right away. it seemed like it had a miss under load, so I did a balance test, and it gave me a code for cylinder 8. did another test 5 min later and the code was gone. is there any way that bad injectors could cause this? that's really the only thing I didn't fully swap out. only 2 injectors were swapped, and I don't know how many miles are actually on the other ones. could it be that it's not getting enough fuel injected thru the injectors to run right and build up boost. also, when I rev the truck in neutral to 3000 it revs faster now than it did before, but it still makes the overdrive light flash and throws a speed sensor code. p0500. soon as I restart the truck the light wont flash no more, but the code stays until I delete and then it stays off until I rev it to 3000 again neutral. also, in neutral it builds more boost then in gear. I get it to build about 7psi in neutral and maybe 2-3 under load. this truck is kicking my ass.
the other thing it did was when i kicked it hard and then started to slow down the tach dropped to 0 for several seconds and then came back up .Doesnt it get the signal from the cam sensor in the front of the engine ? I swapped that out . There was a black one in it and i put a new black one back in it . Swapped it back to the old one but did same thing .
