1 - 8 of 8 Posts
whenever i press on the gas and my turbo spools it sounds like an alien whistling that the only way i know how to describe it, I have a riffraff 6637 and kc turbos balanced assembly put in it with jelibuilt hydra tunes. Anybody know what could be the cause?
Turbos make whistling noises.
So, I would be looking at the plumbing. If the turbo fins are good, then you may have a leak, or something lodged in the plumbing. It's not hard to make an adapter so you can pressurize the plumbing. Here's one example...I used a PVC cap and a schraeder valve.
Don't rule out the serpentine belt slipping, how long since it was new?
i also found out my turbo has in and out play which but i have brand new beatings in there.
Then something is worn in the turbo that the bearings can't fix. Maybe something rubbing inside is causing the noise?
2013 F350 lariat supercab shortbed in 2 tone
i had a 7.3 issue similar to this, turned out that the side to side shaft play allow the exhuast turbine to rub into its back plate, over time there was a good 16th of an inch of metal ground off the veins of the turbine...
1 - 8 of 8 Posts
