Ok, so here it is.
My truck was under powered. I replaced several injectors. It ran somewhat better for a few days.
I cleared the fuel lines and replaced the filter and rail pump.
It won't start now! I don't have any clew what to do next.
Please help???
She might just be air bound on the fuel side now. Id probably try opening the water drain valve on the fuel filter, and bump it over to try and purge air and allow the filter to fill up. If you get fuel spitting out, close the drain and try to start it. Might not be the correct procedure, but that would be my next step considering what you've done... let us know...
Are you getting the WTS light?
Is there fuel in the filter housing?
Have you checked the fuel pressure on the schrader valve on the side of the filter housing while someone is turning the engine over?
I guess he got it sorted out... would have been nice to hear some follow up on it though...
