I towed my buddy's trailer last weekend (6x12) w 2 dirtbikes in it. Not much wt to tow ! LOL. Anyway, i have Edge Insite monitor and EOT(engine oil temp) seems to go up real quick 240-250 degrees ! This is not going up steep hill just going straight road. Dont have coolant prob hooked up yet, but dash gauge is normal !! If i didn't EOT gauge up would never know oil was getting this hot. Oh, trans temp running 175-185. My question is there a problem r is this just normal ?? Could my sensor b bad? Where is EOT sensor on 03 Van ? Any input would b GREAT, Thanks.......
7.3 engine oil temp ?
Not normal for sure. You need to see ECTs. You'll need an independent gauge. The oil cooler rarely has issues on the 7.3. Much more likely a radiator issue or other cooling system problem. Could also be a bad sensor but you will need an independent gauge to confirm. I've never had my EOT go over 194 towing 10k+. EOT is on the back of the HPOP reservoir.
I too have always wondered what is 'normal' for EOT in a VAN. I believe the pickups should run a little cooler considering the vans dont have the best air movement, no intercooler and and the engine compartment is pretty cramped. I personally have seen a max of about 208 EOT with a delta of 14-17 degrees regarding the coolant temps. This was on a hot day (95 deg f) pulling around 2k lbs in the van doing about 80 mph (no trailer). If I back off to about 70 mph, EOT is about 200 deg f +/- 3 deg. i know the 6.0 van can get to about 215-220 EOT w/o issues. But not sure of what the 7.3 motor in the van should be running. Hope this helps.
Anybody have any insight on oil temps in the 7.3 PSDvan?
Thanks guys, in process of installing my ECT wiring. Hope to get to bottom of issue and i'll let y'll know what i find....
I usually see EOT of 197 to 210. When the ambient air is above 93 which is common for FL I see up to 218.
I've yet to see any higher.
Empty, not towing.
My F250's engine oil will get above 220F in hot weather towing in the flats and/or heavy traffic. I wouldn't be surprised if it got higher going up a grade while towing. I've read that today's conventional diesel oil can take 250F but when it reaches 280 or 300 it's in dangerous territory. With our water-to-oil cooler, the engine's radiator should be effective in controlling the oil temperature unless there's a problem with the cooler. My truck's oil temps usually stay within 25 degrees or so of the coolant temps.
