I tried searching but haven't found any addressing this issue, hope someone can straighten me out.
Experiencing hard cold starts (temps in mid 30's) and white smoke at start up.
The Glow Plug Relay showed voltage across the big posts same as batteries (12.5V) with the key on, the small post nearest to the firewall only reading .5V the other reading 12.5V
Replaced the relay (with a cheapie) and it tested @ battery voltage with the key on, all good, started the truck but it was already warm.
I then replaced the batteries cause they were old and due.
Tried to start the next morning, same hard start. I tested the relay and the rear small post is showing .5V again with the key on, 12.5V across the large posts.
Before I go any farther looking for some input on whether the cheap relay could be my issue in combination with the old batteries (thought I read that somewhere but can't find the post now), or if there may be glow plug issues causing the relay to fail.
Merry Christmas All!
