When you shut the engine off, the pressure will pretty much instantly bleed off thru the IPR, which opens when power is removed from it. That's the way it's supposed to work. If you've isolated the oil rails from the IPR/HPOP, and still have a leak, then check your injector o-rings again.
Does it start and run when cold or hot? If so, you're done. If it doesn't start when hot, you may have torn an injector o-ring on install. It could be leaking into the fuel rail or out into the valve cover area.
