hey guys
1996 f350 7.3 powerstroke
not sure what the issue is here.. when i'm driving and i reach 3rd gear (roughly 40mph) the rpms go from about 2700 right down to anywhere from 1000-1400 when the truck shifts. it is an automatic. the engine is then bogged out and the whole truck sort of does some type of shake. the only way to get power back is to let it down shift or to give it copious amounts of throttle. the turbo does not spool at all when this issue occurs (i have a gauge). the weird thing is, sometimes it will not do the shake and will provide a normal amount of power. not sure if it helps but there's about 285k on the engine.
i'm not sure if this issue is also related, but when i shift from drive to either neutral, reverse or park the rpms will dip below 500. it will also happen going from reverse to park, neutral or drive. the rpms will also dip below 500 sometimes when i'm in drive and coasting down a hill.
please let me know why you guys think. thanks i'm advance
