1 - 13 of 13 Posts
I give up! I've been using the search engine it seems like forever which has never worked for me even if I only put one word in the search.
Where do I find the source and part number of the 7.3L PSD upper radiator hose that goes around and behind the serpentine belt instead of through it. I'm going to install a 203 degree thermostat in a few days and I figured this would be a good time to replace the upper radiator hose.
I'm not sure of the part number, but I know you want the one that is set up for a dual alternator. I have found it before on Napa online without looking it up by the part number.
Boy that was fast! I've been searching all morning and in just a few moments I have an answer! Thanks a lot!!
Jim
My source was my Ford dealer. I simply asked the parts babe for an upper radiator hose for a '99 F-250 7.3L with two altenators. She handed it to me. It fit. /ubbthreads/images/graemlins/cool.gif
The local Ford Stealer wanted $30.00 for the dual alt hose, I paid $13 something including tax at Napa.
Wghile you're changing the hose, it would be a good time to flush the radiator, since you have to drain some anyways. Just a thought... /ubbthreads/images/graemlins/phoney.gif
Yeah I'm going to flush my whole cooling system, change hoses, and install the 203* Thermostat and Billet Aluminum Thermostat Housing from Bob Riley of Dieselsite. I'll then refill with the same Low Silicate Fleetguard P/N CC2835 ES Compleat Extended Life Propylene Glycol Antifreeze/Coolant 50/50 Premix that I've been using for years. It comes with the DCA-4 already in it to maintain the SCAs to a 2.5 level.
I'd add Bob's coolant filter too........
Paul B
Discussion Starter · #10 ·
Yeah, I've been going to install a coolant filter for years but not this go around. I've got too many unfinished projects before I start new ones.
Take care,
Jim
Discussion Starter · #12 ·
Per the 2000 Ford F250 Factory Manual:
1. To fill re-install drain plugs and draincock.
2. Add the proper engine coolant mixture to the degas bottle.
3. Move the temperature blend selector to the full warm position.
4. Run the engine until it reaches operating temperature at 2,000 rpm for five minutes.
5. Turn off the engine and allow the cooling system to cool.
6. Add the proper engine coolant mixture to the degas bottle until the coolant level is between the "COOLANT FILL LEVEL" marks.
7. CAUTION: If the air discharge remains cool and the engine coolant temperature gauge does not move, the engine coolant level is low in the engine and must be filled. Stop the engine, allow to cool and fill the cooling system as described.
Start the engine and allow to idle until normal operating temperature is reached. Hot air should discharge from the A/C vents. The engine coolant temperature gauge should maintain a stabilized reading in the middle of the NORMAL range and the upper radiator hose should feel hot to the touch.
8. Repeat Steps 1-7 until the degas bottle level is ok.
New 203 thermostat
It's been a debate with me and my friends about replacing my thermostat with a 203 degree. Did you ever replace yours and if so did you have to change anything else along with it and how did you find the motor to run with the new thermostat...
1 - 13 of 13 Posts
