I had to tow my buddy's '05 cummins over the hill from Grand junction to Colorado Springs. I could only run in second geargoing up the hills, and know that I should be able to do better than that.
Since we were taking it to a diesel shop in town, I figured it couldn't hurt to find out if their mech knew anything about anything. I started picking his brain, and they had a little time to hook it up to a scanner. I also got the opportunity to be involved in the testing process.
This is what we found:
P0476 epc no voltage signal
P0196 epr not funtioning
and the good one
P0281 Cyl. 7 contribution test failure
Other notes, we saw that the hpop was only pushing a little over 500 psi at an idle.
Possible conclusions:
bad o-rings on or near #7 injector
weak hpop
fouled #7 injector
could care less about the epc and epr at this time
Potential solutions:
Rebuild injectors
change injector o-rings again (did that 30K ago about a year...)
install hpop cross over line
replace hpop
diesel flush?
Anyone got any other ideas????? I'm tired of spending all of the money that I don't have chasing demons:wink2:
and the good one
weak hpop
fouled #7 injector
Rebuild injectors
replace hpop
diesel flush?
