Started engine after about 6-7 weeks of not running. Started right up and sounded good. Then I noticed a wet spot and a leak dripping on the ground off of the rear of the right exhaust manifold. The leak is weeping out between the head and the exhaust manifild at the #7 port.
The liquid felt like diesel fuel and felt slippery like diesel fuel.
Only three things changed from last engine start to this start
1. Changed the oil
2. Replaced block heater.
3. Added fuel stabilizer. Tank of fuel has sat for 8 months.
This morning i started the truck wth the injector vc connector for #5 & 7 disconnected. The weeping fuel stopped. After 10 minutes I stopped the engine, reconnected the #5+7 injector harness VC connector and started the engine. It started right up and within 15 seconds the weeping liguid at the #7 port returned.
1. Changed the oil
