Hey Smokie, I was told that 99 to 04 F450's and 550's did come with 19.5's on a 8 lug pattern? I even saw a pic of a 550 car carrier with 19.5's on a 8 lug pattern? Could they have made them on the same pattern that I have and if so do you think they might be in a Ford parts dept somewhere?
Sorry Smokie, didn't read your last post well enough. I see that you have already answered the question. I did find several wheel combos though! Rickson is one and they look like the cream of the crop. Also found American Eagles and American Force wheels. Does anyone have any experience with these last two brands?
American Eagle also makes the dually 19.5"x6" with the correct 8 on 170mm bolt circle to fit your truck. But apparently in alloy only. Eagle Alloy Wheels - Series 058
You cannot put more than one alloy wheel on each rear hub, so you also need two steel wheels for the inside dualies. Where are they? They probably have them in a set the same way that American Force does, but you'll need to verify that to be certain.
ALCOA does make them BUT, you will have to call their 800# to get the part number! The "tire/wheel guys" have a standard answer of no, when/if they don't want to look around for something. In fact Alcoa will change lug patterns to whatever you want but the wheels have no warranty!!
