I have 2wd 84. The bars that run from sides of the front axle just below the shocks to the frame, that has the rubber bushings mounted to the frame with a riveted mount is called what? Bushing is shot. Is this called radius arm?
Yes that would be it.......Radius arm bushing kit is required.
Bushings are available now that allow for camber ajustment. Bushings are threaded.
Some members remove the whole arm, others remove the bracket by drilling out the rivets and installing grade 8 bolts, others and the one way I dislike, they jack the Ibeam ahead until the radius arm pops out of the bracket enough to replace the bushings. So pick your poison.
