I've an '86 6.9, the previous owner had changed out the factory/stock glow plug relay system and installed a 7.3 relay system - this may not affect my question, as it's just a relay for power?
Truck's been getting more stubborn about starting, so figured would check the glow plugs - it's only been about 5 years now!!
Yes, a couple are no longer working. The existing glow plugs are Delphi HDS307 (Delphi HDS307-EYL-5V is what's marked on the glow plugs). Perhaps Motorcraft ZD9 or ZD?.
I'd inquired at the local Ford dealership (know the mechanics n' parts shop folks well, good guys) Parts says listed glow plugs for an '86 6.9 are no longer being carried by Ford.
Was hoping for German glow plugs.
My question is:
What would be proper/you folks recommend, glow plugs to use for replacing in my '86 (NO won't even consider AutoLite and would prefer Beru, as used in my '96 7.3 PS). OR, just order up some Delphi HDS307's n' call it good (realize could use them, but what do you folks consider might be better?). hmm would '87 7.3 glow plugs work, Beru P/N GV823 ???? Existing Delphi glow plugs have the round/bullet tip for connecting to '86 wiring harness.
thank you for your time n' input...
My question is:
