For the past few days my truck [87 f250] has been giving me a fit in the morning.I even ran the batt.s down one time!I had the intake gaskets replaced a while back,after that for some reason the wait to start light quit working.What i've been doing is cycling the plugs by waitng for the clicking sound under the hood[I do this twice]she usually fires up!After i get it going it'll be fine all day.I have noticed that lately when i start the truck almost every time it stumbles a little.
I have checked the fuel lines and yesterday i replaced the rubber
hoses between the injectors.They were in bad shape,but still have the problem.It seems like its turning over good,i had the batt.s checked and they are fine.
Thanks in advance for any help!!
N2ofreek /ubbthreads/images/graemlins/smokin.gif
sounds like a fuel system leak
probably the orings under the return line caps (plastic t's on top of your injectors -- between the lines you just replaced)
they should be replaced all together (t's o-rings and lines)
get a kit (around $30)
do a search, there are links in several old posts to places to buy them
some people use an electric fuel pump to "presuarize the system" forcing the air out, before starting
the holey red pump seemes to be the most popular
solved my hard start problems
and the puddle of fuel on the valley pan
l'm not quite sure what you mean about the glow plugs, but be careful not to cycle them too long -- burns them out sometimes warping them and getting the m stuck in the head, or causing them to drop their tips (into the cylinder !BAD!)
goat
thanks, I will look at the orings this morning after work.
As far as the glow plugs go,I meant the light on the dash doesn't work anymore,I was wondering what the mech. could have did, because the light worked before he removed the intake to replace the gaskets! /ubbthreads/images/graemlins/confused.gif
If somebody was working on the top end of the engine it could be the glow plug controller was disconnected. The ground wire on the GPC is very important.
I replaced one glow plug (Motorcraft only) and at the same time cleaned the ground that goes to the engine from the GPC and it really improved my glow plug cycling. 87s have the newer 7.3 GPC.
It previously was on for a few seconds and then cycled rapidly. After cleaning the ground, it is on for 10 to 15 seconds and cycles much slower.
Then I cleaned the positive battery cable junction and the engine whirs right over and starts great.
thanks for the info guys,I will check the ground now on the gpc.I put the batt. charger on it this morning {i was listening to the radio while i was working on it yesterday}and the thing fired right up!I'm wondering if maybe my srarter is going? Keep the ideas coming cause i'm taking your advice seriously!
tha /ubbthreads/images/graemlins/shrug.gifnks
Your RPMs while cranking should be 150-300 RPMs. You can have both the batteries and the starter load tested at your local auto parts store. If they aren't tip-top, it makes for hard starting.
