I had the IP replaced and the replacement was defective so it was replaced. Found out that the mechanic didn't tighten all the injector lines. Corrected that problem. Was smoking badly from the left bank so replaced all of the return lines and made sure all connections were tight. Starting nice now but with a rough idle and still smoke from the left bank. Decided to go ahead and replace the injectors. It now smokes like a fogging machine from both banks and rougher idle. To recap: new mechanical fuel pump, new (remanufactured) IP, new return lines, new injectors, and ALL connections checked for leaks, Still a lot of white with blue tinge smoke and rough idle. HELP!! I am at my wit's end.
