I'm trying to avoid getting grease in the diesel filter so it looks like I need two solenoids for fuel. I need one before the lift pump to select grease or diesel and then one after the lift pump to bypass the stock filter when I'm pumping grease.
Is this how others have plumbed? There's no room in my engine compartment to put my grease filter so it's going to be at the tank but I'm concerned about having a mechanical pump with no filtration going directly to the IP. If the pump fails or gives off a shaving or two it could really cause some damage to my IP or injectors.
Anyone have some good advice? Will a 40 micron supplemental inline filter keep out the nasties from the pump?
