The truck will start and run for a little while and then die while driving. After the first few times the fuel filter light came on and I changed the fuel filter but it still keeps dying while going and the fuel filter light comes on still. sometimes I need a jump even though the charge gauge says it's got plenty of charge. Any ideas?
It sounds like two things are happening at once. First your lift pump is probably failing. Second your batteries are probably getting weak. The lift pump is located on the passenger side of the engine down low on the block. Same as the old carburated engines with the mechanical fuel pumps.
