I have a 1994 E-350 with the 7.3 idi engine and an E40D transmission. I just finished replacing the head gaskets along with many other things. The transmission worked fine before the head gasket job but now it's not working.
When you put it in Drive it feels like it's either in 3rd or majorly slipping. When you put it in 1 if feels the same way. When you put it in 2 it feels like it's in 2nd. Reverse feels normal. When you start out in 2nd and shift it to D after building some speed it will shift into 3rd but not overdrive. Could this be an electronic issue that's keeping the transmission from going into first gear?
Before the repairs the overdrive off button worked but now it does not light up at all. (I can't remember if it actually lit up before but it absolutely dropped from OD to D when the button was pushed)
The wiring is a nightmare on this thing. I've cleaned up a tremendous amount of it under the hood. There is a problem at the solenoid that's mounted on the drivers side of the radiator support just in front of the battery. Does anyone know what this controls? The previous owner had it powered directly by a cable running to the positive lead of the battery. The solenoid does not work and the red/blue wire that is supposed to activate it does not receive any power. Do any of the wires connected to that solenoid go to the transmission?
Any help is greatly appreciated. I've put over 60 hours into this thing on everything from the head gaskets to the ball joints to brakes, both A/C systems, etc, etc. The transmission was the one thing that worked like it should before the repairs and now it doesnt work.
HELP!!
HELP!!
