Hey everyone I am new here. Need some advice.
I’m swapping out the stock front diff in my 94 f350 and using a 2003 f350. Already completed the rear swap. I have a issue with the Spring pad alignment on the new differential the 03 is 3/4 of an inch wider compared to the 94. Is anyone building Spring shackles to up date the 94?
Sky manufacturing is, i believe they are the only ones too.
You will need to use a Shackle Reverse bracket kit from Sky Manufacturing or PMF Suspension to mount longer better riding 99-04 springs at the right spacing for the SD axle.
see? i sit corrected, PMF as well :p
