help, i have a 94 7.3 not a powerstroke but with the Ford turbo, 175,000 miles and well maintained. i have a couple of problems, when the truck is cold, it takes about a minute -sometimes longer- to start, but once started i can cut it off and it will start fine. during this cycle to start the motor will hit/miss (sound like hit/miss is from the pass side of engine) acouple of times and then a big puff of smoke and then it runs fine. i have changed the glow plugs and checked the relay, i also changed the fuel filter and same thing going on. i thought that fuel might be leaking back to the tank, so i warmed engine and then shut engine off and clamped the rubber line that feeds the mechanical pump and that didn't help, next day, same long start cycle. i replaced all the o-rings clamps hoses ect. on the injectors. i have fuel leaking between the bellhousing and motor. i used about three cans of brake-kleen and presure washed the intake and rear of motor and there is no fuel on intake or back of motor, but is still seeps out of bellhousing / rear of motor. when i pull an enclosed trailer, there is fuel spots on the front of the trailer
