Hi guys thanks for having me here. I am at my wits end I have a 95 f350 powerstroke 4wd automatic transmission. To start at the beginning the stock tranny while driving down the road when you let up on the throttle would seem to go into neutral and when you pressed the throttle to go the engine would just rev up. If you slowed down to about 20 mph sometimes it would go back into 2nd gear and go on. Sometimes you would have to manually shift down into 2nd gear to get it to catch then go on. Sometimes this problem would cause it to go into limp mode and then shift hard on the next shift pattern. We are now on our 3rd (yes count them 1,2,3) jasper remanufactured transmission (not counting the factory tranny) and it is still doing the same thing. I believe the problem is somewhere else. We have replaced all sensors relating to the transmission and all work has been performed by a certified master Ford tech. Somewhere I seen a post that said that the brake lights and turn signals and dome light are on the same circuit as one of the tranny sensor circuits and can cause shifting problems. It is kinda an intermitten problem and does not do it all the time. Please, Please help this is getting very expensive and I am out of ideas.
Merry CHRIST-mas everybody and GOD bless.
