Hi everybody,
Thank you for taking the time to read through this.
Got a 95 F350 that sat outside in cold weather (up to -4) for two weeks. Plugged it in and fired it up when it was about 23 and it turned out the Diesel was still gelled up because it barely started, ran very rough and kept dying for the next hours.
Now, three weeks after it still has the following symptoms:
Neutral revs - YouTube
Idle - YouTube
So far I have done/checked the following:
Other than that I could see it being a bad injector. I unplugged each one of the 4 harness plugs and they all seemed to make the same difference but that's not a very good test, I'll admit.
Idle oscillation could also be the IPR but do the other symptoms fit?
This being a 95, I don't think I can just plug in an OBDII reader unfortunately.
Thank you for any good suggestions!
- Slightly rough idle
- Noticeable engine vibration in Neutral at about 1300 and slight vibration above that, sounds like a miss
- Pulls fine in first and second gear but often vibrates under load in 3rd, 4th and 5th and seems a little low on power
- Every now and then idle oscillates very slightly between 700-750
- There is no noticeable smoke when moving, slight haze when idling
Idle - YouTube
- engine oil is full
- tank is full
- ran Diesel 911 and injector cleaner through it, no difference
- changed fuel filter, no difference
- changed fuel pump, that made it better but didn't fix it
