'95 F250 PSD, 2WD regular cab, 228K miles
Crazy sudden hot start & stalling issue.
Truck ran fine until suddenly, no hot start, stalls easily when you lift your foot off the accelerator pedal.
Starts fine cold.
Shell Rotella Dino oil (changed maybe 500 miles ago)
Batteries are checked good 12.5 volts
New IPR "O" rings (maybe 1000 miles)
New CPS (maybe 2000 miles ago)
New fuel filter & screen cleaned (when I did the IPR "O" rings)
Fuel pressure at idle at schraeder valve over 55psi
For a while the truck has had a habit of being funky returning to idle, when hot when lifting off, so that on returning to idle the engine would get all "fluffy" & wobbly as if there was a miss at say 950rprm down to 750 rpm. Then drop down to a steady idle
What's left injector poppets? Injectors themselves?
There has been an intermittent noise from the passenger bank that I would swear sounded like a ticking lifter, not all the time, come and goes.
Starts fine cold.
