Working on a friends 96 PS engine has no boost. Measuring boost at the map sensor line.
Did find the EBP valve stuck closed. The throttle blade has been removed. Still no boost.
ECM has been replaced
IDM has been replaced
All valve cover/injector harness has been replaced. They were in bad shape.
EBP sensor has been replaced and the supply tube cleaned and checked
ICP is 550/600 at idle and around 2800 at WOT.
No excessive smoke during accels.
Of course cam sensor has been replaced
Does not set any codes
Beginning to suspect injector o-ring maybe leaking?
Any other suggestion would be appreciated
