So a few weeks ago I hadn't started my truck for a while and decided I needed to let it run. I went about mowing the lawn and when I came back to the truck it was running like crap. Missing and no power at all. A visual inspection revealed the uvc harness for cylinders 2 and 4 was burnt. All of the other 3 looked good. Drained fuel filter canister and replaced the valve cover gasket and the one uvc harness on the drivers side. Started truck and same thing; really running lousy. Took truck to local mechanic. He checked the OBD and said #1 cylinder was low output and #5 was no output. Buzz tested injectors and all tested ok. Since he was doing this for free he stopped there and said it would take more extensive testing to determine what the problem was.
At this point I still had one new uvc harness so I put it on the #5 and #7 cylinders hoping for a miracle. Put the truck all back together, fired it up, and wallah. It ran really bad for about three seconds then straightened out, check engine light went out and since then I've ran it about an hour or so and it's still running like a top.
Does anyone have any ideas what might have caused this malfunction? I'd like to avoid having it happen again if possible. Thanks for all the previous help
halfhere
halfhere
