Hi there I have a question about my vans TPS. On my black wire I'm getting the right 5 volts and my yellow is my ground. But my gray wire for sending the info to the cpu on my throttle placement I think needs some help. I'm only getting .1 volts at idle and at WOT I'm getting .08 volts. I checked it against my 2000 F350 and I know its supposed to be 1.2ish - 4.5 WOT. I have already replaced the sensor (pedal assembly from ford) thinking that was the problem. Not sure where else to look.
