Replaced starter solenoid on pass fender and new glow plug relay. Checked neutral safety switch and when I unplugged the neutral safety switch and used jumper wire it started cranking as soon as I turned key on in every key position! The truck does have a auto start installed . The gauges and dash lights act normally when I turn key to crank (they dim and odometer goes momentarily blank) Batteries both load tested good and all cables are clean and tight.
