I just swapped a set of injectors in my 97 and now it will not start! All connections connected, hoop full, has fuel, new fuel filter, opt replaced . It's like the injectors aren't getting power. I need my truck becAuse I don't have a ride please help!!!!!!!!!!!!!! Thanks
I have tried cranking it alot even starting it with ether and wd40 I no its bad but it will not let injectors fire and I did get oil out ofcylinders be4 installin injectors
try unplugging the icp that will send maxium pressurei nt the lines you should just need to get the air out. that can take up to 30 minutes of cranking. double check all your wiring harness. does it sound like its cranking normal?
I've tried that but it didn't seem to make a difference and yes it does turn over fine till it starts to die and I then hook up battery charger
