driving in pouring down rain and my truck just losing power and it died. I just had a water in fuel issue and had changed fliter and dumped bowl prob 50 miles before this happened. I checked fuses and relays on the side of the road and all were good. never had a check engine light. tach was always working when trying to crank. i changed the cam pos sensor. still no luck at recranking. i do have a mt 2500 snapon to diagnose with but i don't know all that much about working system. after looking at codes it said cam pos intermittent . i rechanged it and it still says that code but i read with continuous turning of the motor with no start will cause this. i have hooked the snapon 2500 to a running truck and compared the keyon readings. unless i missed something everything looked the same. what i have noticed is that while cranking, i notice my icp going to around 2400 psi while cranking? i have made the truck run by giving it a small shot of starting fluid. i pullied the ipr out thinking it had failed stuck closed. no evidence of that. put voltage to solenoid and it magnetized a bolt as well in it. any help would be appreciated
