Been researching this for awhile and haven't found definitive information without going and finding parts to physically try it. Hoping someone else has already. I want to know if I can swap out just the hubs from an 07+ axle onto my 2000 axle. The key thing I read was this:
"The Outer Wheel Bearings and Cups are the same for all years, but the inner wheel bearings will vary by build date. For the 2005 Model Year, Ford switched a larger inner wheel bearing and wheel seal. In mid model year 2006, Ford switched back to the smaller inner bearing previously used on 1999-2004 models. "
This is semi-confirmed by looking at bearings and hubs online; seeing "99-04 & 07-16" overhaul kits (and hubs), and "05-06" parts. Here is what I do know (note this pertains to DRW trucks ONLY which all have a Dana 80)
99-04 8x170mm wheel bolt pattern, small inner bearing hub
05-06.5 8x200mm, large bearing hub
06.5 (lets call it 07)-16 8x200mm, went back to small bearing
From scouring part numbers and the information I can find, it looks like 07-16 hubs use the same o-ring, inner and outer bearings.
The brake rotors bolt under the hubs, so I don't think the hub change will affect that.
