I have searched the forums and just looking for help with AE.
99.5 270k on the clock. I have had log crank start since last week. About 4-5 seconds to start. Usually fires over real quick. Truck runs fine otherwise. The IPR was replaced 4 years ago when I got the truck. I had the batteries out and cleaned them up and charged them two days ago and still long crank. Had the batteries tested and one was bad. They were 4.5 years old. So now have two brand new batteries and it still has a long crank. Fuel pressure is good at 65 PSI and tank is 1/2 full.
I havent been drivin it as much because I now have a work truck. I noticed this morning about 50 degree morning. I know that is not that cold that I had the longer crank. Drove it for 1.5 hours. It sat for 4 hours now its in the high 70's went and out and it started just fine.
I was originally thinking a HPO problem but with it starting fine when its warm it seems to me a cold start issue now.
Ok did some AE tests
Tested the KOER Glow plug - No problems
KOEO Buzz test - All buzz fine but get the P1298 IDM Failure (I have a PHP tuner that may be it)
KOER regular test - Get the back pressure valve code probably because I gutted the valve.
Any info on what else to test would be great.
AJ
AJ
