The above post was edited so reread if read earlier.
Where did you get your sensors from? There are many fakes that look pretty real.Oldiesdude; good morning and thankyou; yes, we replaced that same sensor and the plug a month ago as well since it seemed most likely—wish it had been that easy too. Plug off cranking test for that didn’t change things either.
I'd been carrying mine in the glovebox for a long time, but IIRC, I purchased from a Ford dealership on Ebay. At the time they were selling both the ICP and the IPR both were in original MotorCraft packaging. I didn't need to use the IPR at this time.Where did you get your sensors from? There are many fakes that look pretty real.
Hello Maryland Diesel Nick,Are you talking about post #6 or your list’s number 6 ? That says What other items to check.
Do you know what the IPR is and where it is located? You need to disconnect the harness connector and verify that you are getting12 bolts with the key on with just a test light is
fine. The other sensors are to be checked with volt meter looking for 5 volts.
