I've got a '99 F-250 with a 7.3 and 6-spd manual. I was driving down the road today, and the check engine light came on, and the engine started running rough. It was shaking like crazy, and low on power. I turned around and took it straight home. It started fine, but still shaking. It feels like it's only running on 7. Any suggestions? Also, is there an easy way to check codes without a scanner? I know my old GM cars, you could check 'em with a paperclip.
Any help would be appreciated. Also, I changed the oil about 50 miles ago. I checked the oil and the level is fine. I used Rotella T.
Thanks!
Thanks!
