Yeah, i forget to add that I added the thermostat when I flushed the coolant system, there was not one in it when I started. I went with the motorcraft recommended thermostat (195 degrees) and probably put 20 miles on it since then just to get it circulating. I recently bought the truck which had a ton of oil in the coolant reservoir. That is why I replaced the oil cooler seals, flushed the coolant system and installeded the thermostat. I just found it weird that it was towing fine up and down hills at a constant 195 degrees and then suddenly, within 5 seconds it was at 260. I shut it down fast, got towed home and now I guess I'll look for leaks and anything obvious. If it were a clogged radiator or bad water pump, wouldn't i see the temp climb slowly?
