On my E99 the blower all the sudden stop working, all speeds, although a couple of time would come back on. Just wondering if anyone has any knowledge of the power flow on it. I know that the fuse is good. Need to find time with a test light and check things out. Thanks
Here's a wiring diagram. It's for an '01, but should be the same as an early 99.
Turns out that the blower motor is bad. Tap on it and it starts running again.
I had a similar issue. Being a packrat, I still have the original motor.
Glad you got it figured out. Percussive maintenance sometimes helps.
Got the new motor in , what a difference too. Was able to get a Motorcraft one for $60. Glad it was a easy fix.
