Hey guys, new to this site. My passenger window is not working at all. Niether the passenger side switch nor the driver passenger switch will get the motor to run. I took apart the door today to replace the motor. I hooked up the new motor with out installing it just to make sure it works. It did not work! The weird part is that I checked the wires running to the motor for power. When I hit the passenger side switch up power would go to one wire. When I hit the switch down it would feed power to the other wire. So the switch works fine, its getting power....Im stumped. I tried to different brand new motors and neither worked. I am stumped. Are both of the wires leading to the motor supposed to be power or is one supposed to be ground? Thanks in advance! BTW the truck is a 99 f350 7.3 power stroke
My passenger window would not work either. Turned out to be a broken wire in the drivers door boot by the hinges.
Neil.
