Truck has had strange electrical problems for a while.
Started with headlights going off randomly, next start they might work. Then turn signals won't work at random times, next start they may work.
Now engine quits running for 5-10 seconds and restarts with momentum of truck. Happened 3 times in 15 min trip.
Help would be appreciated as this is a fleet truck and used daily. Thanks ahead of time. Keninch
Sounds like you have a problem in the electrical system, possibly a bad connection at the fuse box. If the engine dying coincides with the headlight problem, then it just about has to be in the fuse box. Otherwise, the engine dying intermittently could be a cam position sensor (CPS). The CPS is located on the front of the engine at about 11 o'clock when looking at the crankshaft pulley. If the engine dies when you hit a bump, look at all the electrical connections.
Good Luck and welcome to TheDieselStop.
