Ok I tried doing that and the fan workedI would try a direct feed 12v to the fan motor and see what happens. The brushes on them only last so long.
No there is no flow from anywhereIs there flow volume/pressure coming out anywhere, floor, dash or defrost position?
Fans are not blowing, I hear vacuum pump and I see the blend door move when I turn ac on/ off. Air came on randomly today when I was driving but now it’s not blowing.If you're fan runs, there should be flow ..... somewhere, if the fan has an available supply and outlet media (air) path. However, if you have no vacume the in dash blend door doesn't work. Usually defaults to the defrost position. Do you hear the vacume pump when you " wait to start " KO?
