I know what WVO stands for but what does SVO mean?
B-100 is when you're running 100% boidiesel, right? So a 50/50 mix could be called B-50?
This is from a post by FN74:
"I simply dump the oil in the top 30 gallons at a time, let it heat and settle for a few days, then open the valve into the bucket, where it is then pumped through the donaldson and into the 175gl holding tank."
I thought the wvo needed to be heated first to ease filtering. So if it's heated, then let sit, it's thick again going through the filter, right?
On de-watering: I understand with the hot water tank method of heating the wvo, you open a valve to "exhaust" any water vapors that are extracted during heating. And if you made your own heating tank out of a barrel, you can take the lid off to allow water to evaporate out. Makes sense to me that having a large open lid will let more water out than a small valve. Is this correct, or do both methods work about the same?
Thanks for any input.
