**1995**
My schrader valve on the high-side test port is not sealing. I've changed this #*^% thing once before for the same reason.
I'm leaving my quick-coupler on for now, but I suspect it will slow leak my refrigerant out.
Is there a quick fix for this - other than to suck out the refrigerant and replace the port?
BTW...the new compressor I installed last week shucked its' guts, spread metal throughout.
That cost me an additional filter/dryer, orifice tube, $40 worth of flush stuff, oil, refrigerant charge, and several hours.
Did you look at the pic? You have to remove the valve core, which will dump all the refrigerant in a few seconds. You'd better have fast hands...
And that kit won't work on original Ford service valves with a rubber ball.
Your new compressor probably grenaded because of too much refrigerant, or the oil not being distributed through the system.
Steve, you're correct...the service port must be removed to repair a leak. I had to order the part. You may also be correct on the oil/overchareg...or maybe the compressor was just a chinese-made POS??
So I'm suckin' out the system as we speak.
Autozone sells a compressor now with a lifetime warranty - they've never offered that warranty in the past. To get the lifetime warranty, you must replace the filter/dryer and orifice tube also. I had done all that, so A-Z replaced all three parts under warranty for me.
I've owned the truck since new, and this is the sixth compressor I've had to replace. I had one once before that only lasted two days.
There's nothing like 108 degree day to make one appreciate a working A/C system.
Does that mean YOU did the work all 6 times? If so... :icon_rolleyes:
Ha! About half and half, if memory serves me.
The two-day fix was a local mechanic, a dealership fix lasted 14 months.
If you take out the two immediate failures, I'm averaging a 5 year life on a compressor.
