Hi all,
I was in the middle of installing my new auto meter gauges when I discovered the A-pillar mount was not an exact fit it left a gap at the top. I called Beans and they told me that the Vans don't list a part after 2002 and that is what the part is for, can anyone shed some light on this before I make it work.
Are you removing the stock A-pillar ? On mine it is designed to go on top of the factory one and is attached with two plastic body panel type fasteners. Mine is older though it is an Autometer version 3 guage type . I would just mount it on top of the exhisting factory one . Do you have clearance for the wiring and boost lines with it going on top ? If not you might have to notch the factory one to get the stuff to fit . I have model # 17316
http://www.autometer.com/productPDF/1157.pdf
Is it too long, too wide etc?
Morning:
Suggestion, Call Dennis at ITP he has or had the part you need
(602) 354-7255 If he do not have it he can point you in the right direction
