Yesterday I was driving the truck and the brake warning light came on. This surprised me, because I had just done front pads about 2 weeks ago, and actually overflowed the reservoir when pushing the pistons back in. Not very long after the light came on my pedal started going almost to the floor before firming up - confirming that the fluid level was very low! I pulled over and topped off the reservoir and continued to my destination about 5 miles away being very carefull not to get close to the back of anyone.
Once I go there I immediately looked at the front brake hoses figuring I must have inadvertently stretched one or something when I did the pads and it had now failed. All was dry up front. But, there was brake fluid covering most of the fuel tank, inside of the the left rear inner wheel, and the left side of the axle. The fuel tank is in the way of being able to see where it failed, but it must have simply burst the hard line going to the rear over the fuel tank. The leak is pretty big - left a large puddle in a hurry.
Now for the best part - I had just filled the tank! Doh! Now I gotta pump out almost 40 gallons of fuel so I can fix a brake line... Fun!
So, are there any unions or other connections in the rear brake line up above (actually I guess it's beside) the fuel tank? Anyone else have a failure here?
Jason
Jason
