Probably the vacum pump has failed. CDNSARGUY has the test in his gallery. If it is bad then you will need a pulley puller like whats used on the Power steering pump to take the pulley off/put it on..
Did the vacuum pump work for you? Mine are coming on at random times and when the pedal gets hard the brakes don't release when I take my foot off of the brake pedal.
