My ABS light stays on all the time? What should I check for? Thank you in advance.
You need to pull the codes. You don't need a code reader but you have to ground a wire below the glovebox and count the ABS light flashes for the code.
I'm sure that if you did a search on here you will find a thread on it.
Other than that is your speedometer and transmission working alright? I'm just guessing that you have automatic
Thanks Bugman. It turned out that my emergency brake was not fully in the off position.
