I need to replace the the unit bearing on my late 99 f250 4x4. The local parts stores only have the abs version. Are they interchangeable with the 2 wheel abs trucks? Found a couple posts of the same problem.
My bearing is not bad but someone put an early 99 bearing on there and turned the rotor to match. Bought a new rotor and it hits then caliper bracket. The flange on my suspect hub is 10.5mm and my truck build date is 5/99
