1999 7.3 superduty the air goes off and at will. i have bipassed both hi and low switches. it has power going to the switches and the pump. does this thing have a thermostat switch inside of the cab. does the cab have a filter thanks
The plug is good so i guess i have to look at the air gap thanksCabin filter was a dealer installed option - I've never seen one - just read about them.
Biggest cause of intermittant engagement is the air gap - View attachment 11739
Double check the connection to the clutch - sometimes that plug gets corroded. If jumping the low pressure switch doesn't cause it to engage, and there is power to the connector - the clutch gap is either too great or the electromagnet is going out.
